thebigjay19
May 29, 2019Guide
Xbox X Wired Daily Reboot
Getting pretty sick of this! Tonight, 2 reboots. What the hell is wrong with this router? Wireless is great no issues, so why not the lan port? On the Xbox X? Turn off the Xbox after playing, come bac...
- May 30, 2019
Unfortunately the only advice I can give you for now is to change it to Power Saving mode, but of course then you can't suspend games or download updates overnight.
thebigjay19
May 30, 2019Guide
Maybe, but how so? Is the always on feature that different or difficult? Or is it something else?
May 30, 2019Guru - Experienced User
Been like this since xbox day 1. Happens on other mfr routers, not just NG routers. Some have good luck in using it. Some don't. Something MS needs to address if they are ever going to. MS may not as well. People need to make some noise to MS and something might happen. Took alot of noise and years for MS to finally help fix NAT issues with two or more game consoles online at the same time.
- thebigjay19May 30, 2019GuideThank you FURRYe38. I appreciate your feedback. I will make a post on the Xbox forums as well.
- FURRYe38May 31, 2019Guru - Experienced User
Let us know if you find out anything. Doubtful though.
Good Luck. :smileywink:
