Retired_Member
Mar 10, 2018xfinity 1gb internet slow on http but not https dslreports
Hey guys, I got an xr500 and xfinity gig internet. On the dslreports speetest, if I am running the test on the http version I only get 300mbps, but when I use the https version I get the max (900...
Netduma_Jack
Mar 11, 2018NetDuma Partner
Hi Barrok - this happens because DSL reports uses port 80 to run their tests. Currently that is the only port not hardware accelerated by the router due to the blocking features in settings.
If you try speedtest.net you’ll see full speeds. We'll be implementing something in a future firmware to allow hardware acceleration on port 80.
- Retired_MemberMar 11, 2018Thanks for the responses. After reading that website I have learned a bunch but I don't seem to see any solutions.
Is my only solution to wait for an update? Is Port 80 something all browsers default to? What about steam or battle.net or Netflix. If they all use Port 80 then isn't this a pretty big deal?- Netduma_JackMar 11, 2018NetDuma PartnerNeither of those use port 80 for their main content (Google search will give you a list of the ports they use).
It shouldn’t affect you as most applications needing high bandwidth will use other ports. Let us know if you are having problems - but it shouldn’t impact you. - Netduma-FraserMar 12, 2018NetDuma PartnerHi Barok, I have sent you a PM.
