GhillieK9
Jan 20, 2020Apprentice
Xfinity 1GB speed but only get about 150-200 on my XR700
Hello, I've had the XR700 for a few months now. When I first got it, we had Xfinity's 200MB service and I remember I tried the 1GB for about a month. On the Nighthawk app, I remember my speeds we...
Jan 20, 2020Guru - Experienced User
The nighthawk app speeds aren't reliable testing in my opinion. They do base if off the router but you can't choose the server and some of the servers, struggle to saturate gigabit.
I've taken to testing using: dslreports.org, speedtest.xfinity.com, speedtest.googlefiber.net
These can usually saturate gigabit. the key is making sure your device can saturate a gigabit line. having a gigabit port doesn't mean the device has the processing to hit gigabit speeds.
When you updated firmware, did you try a factory reset? I'm not 100% on the DumaOs devices but some of netgear's other routers have had issues with QoS settings being retained
- GhillieK9Jan 20, 2020Apprentice
I haven't tried those other testing websites but I'll give it a try. I figured the app would show me the speed that the router is actually getting from the modem...so if I use my Macbook Pro and go to one of those other websites...it'll tell me what the speed it via WiFi or ethernet if I have it plugged in.
I've done a full reset today but still the same issue. Out of 10-15 tests, I'll get maybe one that has 850mb speed but mostly between 100-150ish. Just weird. Even when I keep getting around 100, as soon as I do the speedtest.net speed on my phone via WiFi, I get 600+ (again, I know it won't get much higher than that...just odd that the router shows 100ish but phone via WiFi 600+). And if I do Eithernet directly to the modem (CM1100) it is 950ish almost each time.
- Netduma_AlexJan 21, 2020NetDuma Partner
Are you using the same test when you test the speed of the modem and the router?
- plemansJan 21, 2020Guru - Experienced User
GhillieK9 wrote:I haven't tried those other testing websites but I'll give it a try. I figured the app would show me the speed that the router is actually getting from the modem...so if I use my Macbook Pro and go to one of those other websites...it'll tell me what the speed it via WiFi or ethernet if I have it plugged in.
Again, the app doesn't let you choose which server to use and potentially its choosing one that can't saturate gigabit or isn't ideal. especially when you're phone is reliably getting 600mbps+ it makes me think its the nighthawk app.
try those sites and let us know. Test it over ethernet.
- GhillieK9Jan 21, 2020Apprentice
I see what you mean....I just did some tests not using that app and it is almost always around 800 (so via ethernet). Still a bit better going directly to the modem (it was over 900) but I am assuming that is normal that some will drop from the modem to the router? Didn't think it would be quite that much though.
