GhillieK9
Apr 29, 2021Apprentice
Xfinity boosted my speed to 1.2gb, can I achieve that?
Hello, Xfinity just told me that my 1gb speed just got upgraded to 1.2. I have the XR700 router and the CM1100 modem. I see that my modem supports the WAN aggregation (hooking up the two ethernet...
- Apr 30, 2021
I don't see that the xr700 supports wan link aggregation but it does have the 10g port that can be used for wan.
But the CM1100 only has gigabit ports. It uses wan link aggregation for >1gig speeds.
So you can get faster spees that 1 gig with the xr700 but not with how the cm1100 connects to it.
GhillieK9
Apr 30, 2021Apprentice
Oh that's good to know! Thanks! I thought even the WAN was only up to 1.0.... Does the same apply to the modem's WAN?
Apr 30, 2021Guru - Experienced User
- GhillieK9Apr 30, 2021ApprenticeOkay thank you! I'll look into a different modem. Thank you all
- plemansApr 30, 2021Guru - Experienced User
Keep in mind the xr700's 10g port is a sfp port. Its not a standard ethernet connection so would need a sfp connector/adapter.
They're not exactly cheap.
- GhillieK9Apr 30, 2021ApprenticeDo you know much about the Motorola MB8611 DOCSIS 3.1? It has a 2.5gb port so looks like that would work for me...
