Quapa
Aug 20, 2021Tutor
Xfinity speeds now half with upgrade to CM2000 modem + XR1000 router
ISP: xfinity
Internet Plan: Blast! Pro + Internet (speeds up to 400Mbps)
Replaced my AC1750 cable modem router (c6300) that was previously on the same xfinity internet plan. Speedtest.net tested wifi at a consistent +450Mbps down / 11.5Mbps up. Laptop hardwired in Speedtest.net tested again at a consistent +450Mbps down / 11.5Mbps up. Both with consistent 19ms ping, 2.2ms jitter, and 0% packet loss.
However, my hardwired ps5 Test Internet Connection test results were not as good, with inconsistent numbers ranging from 89-270Mbps down / 500Kbps-11Mbps up. Ps5 over wifi was consistent at 120Mbps down / 11Mbps up. (note: I've tried multiple ca6 cables with no luck)
The purpose of purchasing the CM2000 and XR1000 was to get greater consistent speeds that I'm paying Xfinity for. I've restarted both the modem and router numerous times and ran speedtest.net inbetween with no change in data. The odd part is that the XR1000 Duma OS has a Connection Benchmark feature and when I run the test it reads:
Down: 387Mbps
Up: 12Mbps
Average ping: 17.3ms
Jitter: 0.63ms
Packet loss: 0.00%
Ping Test (under load)
Download: 36.51ms
Upload: 46.08ms
Idle: 18.19
XR1000 firmware version: V1.0.0.58_1.0.44
Why am I not achieving equalto or greater speeds with my new set up over my previous dated modem/router combo??
Help.
- Netduma-LiamNetDuma Partner
Thanks for posting, is it just the PS5 that's not seeing full speeds through the XR1000? Do you have any other wired/wireless devices that are also seeing slower speeds?
- QuapaTutorNone of my devices are no longer achieving decent speed. I’ve ran speedtest.net on my work laptop, personal laptop, and iPhone. Prior to the switch in equipment I was getting much much better speeds. My main reasons for switching was to hopefully help my ps5 achieve greater speed and to future proof for Gig or fiber internet later down the line.
Have you configured QoS? If you completely disable it from the three-line menu in Congestion Control, do speeds then increase?
