Davey1986
May 19, 2021Initiate
XR 1000 and BT Full Fibre 900
I have recently had BT Full Fibre (900mbps) installed at my house. An OTP box was installed that BT said would act as a modem. The BT Home Hub works fine directly though this but when I try to switch...
- May 19, 2021It's possible that you require PPPoE to get internet directly through the box, I know BT used to use this. I'd ask them whether you need PPPoE to connect a router to the box, otherwise if you access the BT hub that may have the information there that you can take and then put into the XR.
Netduma-Fraser
May 19, 2021NetDuma Partner
Davey1986
Hi, thanks for the quick reply. You were exactly right. I put the PPPoE log in details (by default ones) into the internet setup settings and now I'm up and running. Thank you very much
- Netduma-FraserMay 19, 2021NetDuma PartnerGreat to hear that, you're very welcome!
