jame0174
Jul 27, 2022Tutor
xr 1000 high ping
when i use the xr1000 i get high pings.But when i use the duma r2 i get low ping of 13 .my ping with the xr 1000 is 37.I am using the same set up any help would be great.
Netduma-Liam
Jul 28, 2022NetDuma Partner
How are you measuring your ping exactly? Are you looking in-game or are you checking using something else?
Are you using QoS? If so, could you please share your configuration?
If you're using Geo-filter, could you please also share your configuration for that?
jame0174
Jul 28, 2022Tutor
I am using speedtest.net both routers are set up alike.same qos same congestion control .I pay for 950 down and 40 up i also noticed in game ping is also higher on the xr1000 compared to the r2.I don't use strict mode or filtering
- Netduma-LiamJul 29, 2022NetDuma Partner
Could you please share your QoS configuration? Just attach a screenshot if that's easier.
Are all device on the network connected to the XR/R2 when you're testing? Or do some devices still connect to the ISP router/modem?
- jame0174Jul 29, 2022Tutor
Every thing is hooked up to the routers .cable modem router nothing but router to cable modem.ICan u please explain how to screen shot I'm using windows 10.thank you
- Netduma-FraserJul 30, 2022NetDuma PartnerHere is a guide on how to do so: https://support.microsoft.com/en-us/windows/use-snipping-tool-to-capture-screenshots-00246869-1843-655f-f220-97299b865f6b
