jame0174
Jul 27, 2022Tutor
xr 1000 high ping
when i use the xr1000 i get high pings.But when i use the duma r2 i get low ping of 13 .my ping with the xr 1000 is 37.I am using the same set up any help would be great.
jame0174
Jul 29, 2022Tutor
Every thing is hooked up to the routers .cable modem router nothing but router to cable modem.ICan u please explain how to screen shot I'm using windows 10.thank you
Netduma-Fraser
Jul 30, 2022NetDuma Partner
Here is a guide on how to do so: https://support.microsoft.com/en-us/windows/use-snipping-tool-to-capture-screenshots-00246869-1843-655f-f220-97299b865f6b
