jame0174
Jul 27, 2022Tutor
xr 1000 high ping
when i use the xr1000 i get high pings.But when i use the duma r2 i get low ping of 13 .my ping with the xr 1000 is 37.I am using the same set up any help would be great.
Netduma-Fraser
Aug 05, 2022NetDuma Partner
Sorry about that, here you are: http://support.netduma.com/en/support/solutions/articles/16000074717-how-to-test-your-internet-ping
jame0174
Aug 05, 2022Tutor
here is the xr 1000 pingplot
- Netduma-FraserAug 06, 2022NetDuma PartnerCould you do the same from the R2 so we can compare?
- jame0174Aug 11, 2022Tutor
here is the r2 ping plot my r2 just got bricked???
- Netduma-LiamAug 12, 2022NetDuma Partner
The base ping of the two is basically the same, were these done with the network under load or was the network fairly quiet at the time?
If it was fairly quiet, can you add a rule to Traffic Prioritisation for the device you're testing on and select the service "ICMP Ping".
Then, start a big download through something like Steam and run the test again.
If we can then compare these results with each other we can see how the router's are behaving under load.
- jame0174Aug 12, 2022Tutor
They both was while i was playing battlefield 2042 on ps5.
That wouldn't of generated any load that you'd notice in Ping Plotter, although it is interesting.
Were they still reading very different pings in Battlefield, despite being the same in Ping Plotter?
