JOHN2N
Jan 17, 2023Tutor
XR 1000 internet setup to wifi
Is it possible to hook up XR1000 to internet without using ethernet cable. I used cable to setup but would prefer to use wifi for better location and lack of wired connection. How do I do it? Thanks....
- Jan 18, 2023
Thanks, I will get a powerline adapter.
Netduma-Fraser
Jan 17, 2023NetDuma Partner
It does need to be connected via ethernet cable. You could use a powerline adapter from the ISP router and then connect the XR1000 into that but it has to get a wired connection in some way.
- JOHN2NJan 18, 2023Tutor
