Gilephor
Jul 06, 2023Guide
XR 1000 Slow Speeds In Router Mode
Hello all and thanks for taking time to read and digest this. I will get straight into the issue I have a Netgear XR 1000 Gaming Router running running the 1.0.0.68 firmware. I have 1G speeds from m...
- Jul 06, 2023You say you're not running QoS, does that mean you've left their options at their defaults or you've disabled it completely? If you haven't that should get you the higher speeds. You can do this by clicking the 3 line horizontal icon top left of the Congestion Control panel on the QoS page.
Netduma-Fraser
Jul 06, 2023NetDuma Partner
- GilephorJul 06, 2023Guide
Thanks this was it. I thought once you selected NEVER under QoS that was the end of it, I did not know there was an extra screen to turn it off entirely. Again, thanks 🙂 I am now getting the gigabit speeds.
