chrismcglock
Dec 12, 2021Aspirant
XR 300
XR300 1.0.3.56_10.3.41 Hi I have been experiencing a lot more lag then I use to get recently so I checked if the router needs to be updated but it says its up to date. I then checked duma os dash...
Netduma-Fraser
Dec 12, 2021NetDuma Partner
Can you attach a screenshot of the entire page/browser of what you're seeing please?
chrismcglock
any suggestions on how to attach a screenshot from a mac? its saying its to big?
- FURRYe38Dec 13, 2021Guru - Experienced User
This is what I use for OSX:
Take screenshot of a specific region
Press Command + Shift + 4 and your cursor will turn from arrow to crosshair. Move and drag the crosshair cursor on the region you want to take screenshot of and it will be saved on your desktop.
