chrismcglock
Dec 12, 2021Aspirant
XR 300
XR300 1.0.3.56_10.3.41 Hi I have been experiencing a lot more lag then I use to get recently so I checked if the router needs to be updated but it says its up to date. I then checked duma os dash...
chrismcglock
Yes thank you! When I login to duma os it says script error 5-8x before letting me in then shows this.
Netduma-Fraser
Dec 12, 2021NetDuma Partner
Can you attach it instead otherwise we have to wait for the picture to be moderated. You may need to do a factory reset then in that case to resolve the error and the other issue
- chrismcglockDec 13, 2021Aspirant
they went through above
- Netduma-FraserDec 14, 2021NetDuma PartnerI've removed the pictures as they show your IP address. That's just the dashboard, you can see Devices in Device Manager and adjust speed on the QoS page. You can then repin the panels to the dashboard if preferred.
- chrismcglockDec 16, 2021Aspirant
I can no longer access device manage or QoS page anymore. There is nothing in my side bar
