CrossCarrier
Feb 20, 2020Aspirant
XR 450 Wifi Speed slower than Wired
I have a XR450, and theoritcally a 5ghz should be able to go past 300MBS right? I'm standing right next my router and I am pretty sure I turned off all of those settings which might limit speed. I'm ...
Netduma-Fraser
Feb 20, 2020NetDuma Partner
If there are wireless devices such as phones, headsets etc within close proximity of the router than can interfere with the signal so move any of these devices at least 3 feet away. Also use a WiFi analyzer to find the least congested channel and then change to that and redo the speed test.
CrossCarrier
Does DUMAOS have a wifi anazlyer?
