RaysNation
Feb 23, 2022Aspirant
XR 500 - High ping under load
Hi! So I have this problem with very high ping under load. Speed and ping test is great, but download under load has very high spikes. A friend of mine has the same router and internet actually and...
Feb 23, 2022Guru - Experienced User
You'll get better results in the pro-gaming forum that your router is.
The guys on there are very responsive and helpful.
Nighthawk Pro Gaming Routers - NETGEAR Communities
include what modem/gateway the router is connected to, the firmware you're on, if its specific games with issues, and what settings you're using for qos
