RaysNation
Feb 23, 2022Aspirant
XR 500 - High Ping under load
Hi! So I have this problem with very high ping under load. Speed and ping test is great, but download under load has very high spikes. A friend of mine has the same router and internet actually and...
Feb 23, 2022Guru - Experienced User
How are you connected to the router? Wired or wireless?
- RaysNationFeb 23, 2022AspirantLatest firmware is v.2 3.2.130, my friend has the same one. Its connected to a home router (zyxel), its connected through bridge mode. Funny thing is my friend has the exact same setup, extremely strange really..
Here is the test by the way with sliders at 70/70.- Netduma-LiamFeb 23, 2022NetDuma Partner
Was Congestion Control set to 'Always' when you ran this test?
Are all devices on the network connected to the XR500 or are some still connected to the upstream ISP router/modem?
What speeds do you expect to get from your ISP, are they approximately what you're seeing in Connection Benchmark?
- RaysNationFeb 23, 2022AspirantAlways yes.
Yep, no other device can connect to the other as its in bridgemode, so only possible connection is on netgear xr 500. Expect 200/200 and its just what im getting (201/202) in test. Very strange Ive tried adjusting the congestion within all ranges.
