RaysNation
Feb 23, 2022Aspirant
XR 500 - High Ping under load
Hi! So I have this problem with very high ping under load. Speed and ping test is great, but download under load has very high spikes. A friend of mine has the same router and internet actually and...
RaysNation
Latest firmware is v.2 3.2.130, my friend has the same one. Its connected to a home router (zyxel), its connected through bridge mode. Funny thing is my friend has the exact same setup, extremely strange really..
Here is the test by the way with sliders at 70/70.
Netduma-Liam
Feb 23, 2022NetDuma Partner
Was Congestion Control set to 'Always' when you ran this test?
Are all devices on the network connected to the XR500 or are some still connected to the upstream ISP router/modem?
What speeds do you expect to get from your ISP, are they approximately what you're seeing in Connection Benchmark?
- RaysNationFeb 23, 2022AspirantAlways yes.
Yep, no other device can connect to the other as its in bridgemode, so only possible connection is on netgear xr 500. Expect 200/200 and its just what im getting (201/202) in test. Very strange Ive tried adjusting the congestion within all ranges.- Netduma-LiamFeb 24, 2022NetDuma Partner
Do you know if you require PPPoE, VLAN or DHCP identifiers for you connection? If so, are you able to have the upstream modem/router handle that and test if you're still having the same issue?
- RaysNationFeb 24, 2022AspirantDHCP!
Hmm, not quite sure how? The modem/router is in bridge so basically nonfunctional.
Its very strange to say the least. Speed, upload and general ping is great, but under the load the spikes on download are crazy.
Just to inform that these spikes happen 6 in the morning, or 6 in the afternoon (doesnt matter if people are using the internet or not), same outfall. My friend gets A+ every single time. We both have fibreline.
Thanks for helping!
