Nrichards711
Jun 07, 2019Aspirant
XR 500 and Comcast xfinity gig internet Incompatable
Hell everyone, A few months ago, I purchased the Netgear XR500 pro gaming router. My current ISP at the time was Spectrum and I had 400 Mbs service provided to my apartment. Well 4 days a...
Netduma-Fraser
Jun 07, 2019NetDuma Partner
They did give you incorrect advice, a router will work with basically any modem/router - likely don't want you using a third party router or haven't heard of the router yet.
What is the actual issue that you're having? Is it reaching your speeds? Did you use the setup wizard to setup the router again on the new connection or just plug it in without doing so?
Nrichards711
Jun 08, 2019Aspirant
Everything is hardwired to the router. Laptop, PS4, Tv.
- plemansJun 08, 2019Guru - Experienced User
Are you using QoS? Try disabling/enabling it to see if it helps.
Another thing you can try is enabling/disenabling IvP6. I've had this help before.
- Nrichards711Jun 08, 2019Aspirant
I usually use QOS. Just ran a speed test on speedtest.net
But when I ran the install wizard it set my router for QOS 488 because thats what it read... Do I have to redo the wizard for it to know its 1000 MBS? or is there a way to manually set it.
Ran a speedtest again still only pulling 500/600/800 Mbs its all sporatic and nothing consistent.
