NukeBoom
Dec 05, 2020Aspirant
XR 500 can't connect to server or DLAN over WIFI
Hallo, i have problem to access my plex server or dlan server or haxball server over WIFI. Server is in Ethernet. Can somebody helps me ? Best Regrads Nuke
Netduma-Fraser
Dec 06, 2020NetDuma Partner
Try disabling QoS completely from the Anti-Bufferbloat menu and see if that helps at all.
- NukeBoomDec 06, 2020Aspirant
i have in QoS Never checked
- NukeBoomDec 07, 2020AspirantWhere's the wireless isolation checkbox like on my old router?
- Netduma-FraserDec 07, 2020NetDuma PartnerI don't mean Never on the sliders, on Anti-Bufferbloat there is a 3 line option menu in the top left of the panel, click that and disable QoS entirely there. There isn't an option for that, if there was then enabling it wouldn't help with the issue.
- NukeBoomDec 07, 2020AspirantIt disabled!!! I'm not dump. I read many website about this. And I have a new problem also. When I share a usb over internet. The max download from the usb is max 10bits. I connected over pppoe and vlan 35 0
