NukeBoom
Dec 05, 2020Aspirant
XR 500 can't connect to server or DLAN over WIFI
Hallo, i have problem to access my plex server or dlan server or haxball server over WIFI. Server is in Ethernet. Can somebody helps me ? Best Regrads Nuke
NukeBoom
Dec 07, 2020Aspirant
Server configured with upnp.
Should I buy a asus router?
Usb Share is still on 10mbits update
Netduma-Fraser
Dec 07, 2020NetDuma Partner
Use port forwarding instead for the server and see if that allows access. It could be VLAN that is the issue also, if you have another router handle VLAN does it work?
- NukeBoomDec 08, 2020AspirantHi. I set port forwarding manual on the xr500 for the Server. Still not working. I have one from sip and it works with upnp over wifi and lan.
Vlan is set for all. And could be, is not a professional answer. You don't have any idea, why this don't work. - Netduma-FraserDec 08, 2020NetDuma PartnerThat one works with the XR or WiFi/LAN? I am basing that off issues such as QoS not working well with VLAN so the optimization of VLAN and other features is not great. Hence why it could be the cause and I asked you for a way for us to either rule it out or confirm that is the problem. If I knew the exact reason immediately we wouldn't be in the troubleshooting stage.
