digruski
Dec 26, 2019Follower
XR 500 Constant Disconnect/Reconnect iPhone XS (and haywire logs)
So my network is this: ISP Modem(Wifi Disabled) -> XR500(Router Mode): Vivint Panel HP OfficeJet Amazon Firestick x2 Apple TV Xbox One iPhone XS (the offender) +/- 2 other iPhones at an...
Netduma-Fraser
Dec 27, 2019NetDuma Partner
That MAC address is from a device created by the Wistron Neweb Corporation, this could be a Sky Box for example if you're in the UK. I would suggest on the devices you're having trouble on that you 'forget' the WiFi network completely on each device and then reconnect by retyping the password in and see if that resolves it.
