bdk1975
Oct 17, 2020Follower
XR-500 Dropping some (but not all) devices DAILY
Hello, I've been dealing with an issues for the better part of a year now and I'm about ready to ditch the routher....hoping it's just me doing something wrong that can be easily tweaked. The ...
Netduma-Fraser
Oct 17, 2020NetDuma Partner
I'd first recommend that you upgrade to the beta and see if that resolves it. https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/bd-p/en-home-beta-npg-duma
Also if you're using Smart Connect for WiFi I would disable that and connect to either 2.4 or 5GHz manually.
