TottsForScott
Mar 16, 2020Follower
XR 500 Geo Filter issues
Hey Everyone, The issue I'm having is that I'm playing Destiny with a buddy from work and we're trying to load into Mars together and somehow cant seem to find one another. He lives right by me a...
Netduma-Fraser
Mar 17, 2020NetDuma Partner
The way Destiny works is that it doesn't always rely on P2P, it also uses dedicated servers. There will also be many instances and so that makes it harder to find people if you're not directly inviting them to the game. To clarify, it may not be possible or easy to do it this way. If it were to work I'd suggest putting both your locations in the same spot in the ocean where no servers/players would be located and trying it that way.
