akayoshi
Jan 11, 2019Follower
XR 500 keeps cutting my download speed in half on my wired PC.
I just bought this router a couple days ago and it was easy to set up, but ever since i've set it up my download speed is at 50mb or less, but it should be at 100 or close.
I've looked through ...
Netduma-Fraser
Jan 11, 2019NetDuma Partner
If you phone is getting higher than what a wired speed test is saying and the internal speed test reports the correct speed then it sounds like a specific issue with that device or the ethernet cable being used
