Willback15
Sep 21, 2022Follower
XR 500 keeps rebooting
So my XR 500 just started reseting multiple times a day. I got it in april and had no issues but lately it has gotten bad. Ive tried hard reset and changing the wall outlet but nothing. The wifi from ...
Sep 21, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Be sure to change the default IP address pool range to 192.168.1.100 to .200. Apply an reboot the router.
