Nightfall1293
Dec 06, 2019Aspirant
XR 500 lag spike
[LAN access from remote] from 185.209.0.18:47659 to 192.168.1.6:3406, Thursday, December 05, 2019 20:16:08 [LAN access from remote] from 92.63.194.148:55570 to 192.168.1.6:60117, Thursday, December ...
Netduma_Alex
Dec 06, 2019NetDuma Partner
Do that lag spikes occur accross your connection or only in this one game?
Have you tried (in order to eliminate possibilities) going to the QoS menu, opening the Anti-Bufferbloat side menu and ticking Disable QoS?
Could you install PingPlotter and run some tests with and without the XR500? Also with and without QoS Disabled?
