jeremyg237
Jan 22, 2019Luminary
XR 500 Network map not showing wired xbox one x
I have tried to reach out to a couple others forums on here without any solutions. The only way I can get the xbox one x to show up is either rebooting, unplugging or flushing cloud. This issue has s...
- Oct 05, 2019
I started this thread in January. Still not fixed. There is nothing that can be said on my disappointment with this issue. A gaming router that can see consoles and will not fix it. That is the issue. Also you lost a costumer. Once this thing breaks I am not going to get a netgear again.
Jan 22, 2019Guru - Experienced User
What broswer are you using? Try FF or Opera? Same thing?
Disable Instant On?
- jeremyg237Jan 22, 2019Luminary
I use google crome, which they recommend.
- Netduma_JackJan 23, 2019NetDuma Partner
Could you try disaling Instant On to see if that fixes the problem?
- FURRYe38Jan 23, 2019Guru - Experienced User
- jeremyg237Jan 23, 2019Luminary
Tried Opera and it did not work.
