jeremyg237
Jan 22, 2019Luminary
XR 500 Network map not showing wired xbox one x
I have tried to reach out to a couple others forums on here without any solutions. The only way I can get the xbox one x to show up is either rebooting, unplugging or flushing cloud. This issue has s...
- Oct 05, 2019
I started this thread in January. Still not fixed. There is nothing that can be said on my disappointment with this issue. A gaming router that can see consoles and will not fix it. That is the issue. Also you lost a costumer. Once this thing breaks I am not going to get a netgear again.
jeremyg237
Jan 23, 2019Luminary
Tried Opera and it did not work.
Netduma-Fraser
Jan 23, 2019NetDuma Partner
Did you try Jack's suggestion?
- jeremyg237Jan 23, 2019Luminary
So I think I fixed the issue for me. I changed IPV6 from auto detect to auto config. Now the xbox is showing in network map.
- FURRYe38Jan 23, 2019Guru - Experienced User
If your ISP doesn't support IPv6 natively, you can disable it.
- MyuuKunJan 23, 2019Tutor
I am starting to think that it's a firmware/OS issue, I have the same issues with the device list. when the device shows offline it doesn't show up in the network traffic monitor and I suspect it won't be managed by the QOS filters either. As an FYI only 5 devices will show up on the network traffic monitor.
I went to the DumaOS forums and found many threads with this exact issue for the Nighthawk but I found a lot of the devs and admins replying to threads so you may have more luck there.
