jeremyg237
Jan 22, 2019Luminary
XR 500 Network map not showing wired xbox one x
I have tried to reach out to a couple others forums on here without any solutions. The only way I can get the xbox one x to show up is either rebooting, unplugging or flushing cloud. This issue has s...
- Oct 05, 2019
I started this thread in January. Still not fixed. There is nothing that can be said on my disappointment with this issue. A gaming router that can see consoles and will not fix it. That is the issue. Also you lost a costumer. Once this thing breaks I am not going to get a netgear again.
jeremyg237
Jan 26, 2019Luminary
My sons xbox that is wifi has the same issue.
Netduma-Fraser
Jan 26, 2019NetDuma Partner
Okay, I'll pass this on to my team to have a look into.
- jeremyg237Jan 26, 2019Luminary
Thank you
- jeremyg237Jan 27, 2019Luminary
Looks like I might of stumbled on to something. I was bored with a game I have been playing forever and decided to look at my games. Almost all of my ready to install games were missing. So I just searched for it in store and got it. Then I decided to take my xbox off of geo filter by deleting it and then went to QOS and deleted it from traffic prioritization. When I went back to look at more games in my ready to install area they were all back. Im thinking geo filter, but who am I. I am going to keep it all off tonight and try tomorrow if the xbox pops back up on device manager etc. Hopefully this helps the team.
- jeremyg237Jan 28, 2019Luminary
Got up this morning and turned both the wireless and wired xbox on. Both did not show up on network monitor or manager. Once again I unplugged the router and then they were on network monitor and manager. Hope this info helps.
- Netduma_JackJan 28, 2019NetDuma Partner
So to confirm, the only way you can see these devices is by restarting your router?
This may have been asked before, but the next time they do not appear, could you go to System Information and see if your CPU graph is maxed out? It's not likely to be, but worth checking. Thanks.
Yes I have to unplug the reboot/unplug router.
The CPU was at 50
[DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Monday, January 28, 2019 16:18:53
[DumaOS] applying qos for zone lan, Monday, January 28, 2019 16:18:48
[DumaOS] applying qos for zone wan, Monday, January 28, 2019 16:18:48
[DumaOS] Ubus object 'com.netdumasoftware.qos' added, attempting to bind pending, Monday, January 28, 2019 16:18:44
[DumaOS] Ubus object 'com.netdumasoftware.hybridvpn' added, attempting to bind pending, Monday, January 28, 2019 16:18:44
[DumaOS] Ubus object 'com.netdumasoftware.devicemanager' now bound, Monday, January 28, 2019 16:18:44
[DumaOS] NSS delete root for interface 'br0', Monday, January 28, 2019 16:18:44
[DumaOS] applying qos for zone lan, Monday, January 28, 2019 16:18:44
[DumaOS] NSS delete root for interface 'brwan', Monday, January 28, 2019 16:18:43
[DumaOS] applying qos for zone wan, Monday, January 28, 2019 16:18:43
[DumaOS] config write 'com.netdumasoftware.devicemanager.database', Monday, January 28, 2019 16:18:41
[DumaOS] Ubus object 'com.netdumasoftware.hybridvpn - Netduma_JackJan 29, 2019NetDuma Partner
Thanks for sharing the logs but that all looks ok.
We will need to look into this - it's a tricky one though as we have not been able to replicate it ourselves.
- FURRYe38Jan 29, 2019Guru - Experienced User
Could this be something with the xbox code on the console? I've seen odd issues with different xbox consoles and how they are connected and use uPnP. Depending upon which one is turned on first. Also most seems like this is a xbox issue rather then a router issue.
- Netduma-FraserJan 29, 2019NetDuma PartnerCould be but the device manager doesn't necessarily go on ports when determining what device is actually connected
Ya I presumed. DM maybechecking ARP or HostName with Mac and IP addressing?
Netduma-Fraser wrote:
Could be but the device manager doesn't necessarily go on ports when determining what device is actually connected - Netduma-FraserJan 29, 2019NetDuma PartnerYep so I think it is more to do with the router rather than the Xbox but I'm not a developer. They'll figure it out!
:smileywink:
- jeremyg237Jan 29, 2019Luminary
Now other devices are not showing as well. I was showing my wife what was going on and turned on the IPAD. I could connect to internet and go on sites etc but it did not show up as well.
Also I use a SB 6183 modem arris.
- Netduma_JackJan 30, 2019NetDuma Partner
Ok, thank you for the additional info
- jeremyg237Feb 03, 2019Luminary
SO I am still getiing auto ping to host even though itsd not showing on network monitor/manager. Does that mean it is still working as far as netduma is concerned. Whicj I could live with.
- FURRYe38Feb 03, 2019Guru - Experienced User
Starting to think that maybe your unit is just bad. You might reach out to NG support and ask about a RMA:
https://www.netgear.com/mynetgear/registration/login.aspx
- Netduma-FraserFeb 05, 2019NetDuma PartnerJeremy are you actually getting ping statistics on the Geo-Filter?
- jeremyg237Feb 06, 2019Luminary
YES
- Netduma-FraserFeb 06, 2019NetDuma PartnerIcons appear on the map? How did you manage to add your console to the Geo-Filter, does it show it in lists e.g. when adding to Geo-Filter, Traffic Prioritization, VPN Hybrid but just not on device manager/network monitor? Does it appear in bandwidth allocation?
Icons appear on the map? Yes
Does it show it in lists when adding to Geo-Filter? Yes
Traffic Prioritization? Yes
VPN Hybrid? Yes
Device manager/network monitor? No
Does it appear in bandwidth allocation? Yes
- Netduma-FraserFeb 06, 2019NetDuma PartnerYes thats very helpful actually, thanks a lot for the info. I'll pass it on to our team!
- jeremyg237Feb 19, 2019Luminary
Any new info?
- Netduma-FraserFeb 19, 2019NetDuma PartnerNothing new at the moment but we've had a few more users on our own forum who've had the issue so we'll hopefully be able to narrow it down soon.
- jeremyg237Feb 20, 2019Luminary
I think if you had a questinare to send out it might help more. ex all settings etc on the router.
