jeremyg237
Jan 22, 2019Luminary
XR 500 Network map not showing wired xbox one x
I have tried to reach out to a couple others forums on here without any solutions. The only way I can get the xbox one x to show up is either rebooting, unplugging or flushing cloud. This issue has s...
- Oct 05, 2019
I started this thread in January. Still not fixed. There is nothing that can be said on my disappointment with this issue. A gaming router that can see consoles and will not fix it. That is the issue. Also you lost a costumer. Once this thing breaks I am not going to get a netgear again.
Aug 05, 2019Guru - Experienced User
Anyone tried checking for new FW on there XR500?
tfbit
Aug 06, 2019Tutor
If I check for update I only get 2.3.2.40.
- Netduma_AlexAug 06, 2019NetDuma Partner
Either Xr500 was lying or they're doing a limited rollout.
- tfbitAug 16, 2019Tutor
V2.3.2.56 showed up on my check for update!
- Netduma_AlexAug 16, 2019NetDuma Partner
Yes indeed it's really out now for real this time
