jeremyg237
Jan 22, 2019Luminary
XR 500 Network map not showing wired xbox one x
I have tried to reach out to a couple others forums on here without any solutions. The only way I can get the xbox one x to show up is either rebooting, unplugging or flushing cloud. This issue has s...
- Oct 05, 2019
I started this thread in January. Still not fixed. There is nothing that can be said on my disappointment with this issue. A gaming router that can see consoles and will not fix it. That is the issue. Also you lost a costumer. Once this thing breaks I am not going to get a netgear again.
Aug 16, 2019Guru - Experienced User
jeremyg237
Oct 05, 2019Luminary
- Netduma-FraserOct 06, 2019NetDuma PartnerI understand your frustration, we are working on a new version that should fix a lot of issues like this while simultaneously bringing out new features.
- FURRYe38Oct 07, 2019Guru - Experienced User
My XR450 sees both of my Xbox consoles since day one.
- jeremyg237Oct 07, 2019Luminary
Notice the 450 and not 500. Seems to be a 500 issue.
The 450 and 500 are the same HW, less the 2.4Ghz radios. Same code base in FW.
