jeremyg237
Jan 22, 2019Luminary
XR 500 Network map not showing wired xbox one x
I have tried to reach out to a couple others forums on here without any solutions. The only way I can get the xbox one x to show up is either rebooting, unplugging or flushing cloud. This issue has s...
- Oct 05, 2019
I started this thread in January. Still not fixed. There is nothing that can be said on my disappointment with this issue. A gaming router that can see consoles and will not fix it. That is the issue. Also you lost a costumer. Once this thing breaks I am not going to get a netgear again.
jacegibson
May 07, 2019Star
im having this same issue. my xbox always stays on the network but my laptop, ipad, iphone and some unammed devices is showing up offline even though they are online. tried connecting to 2.4 5. the access point. hard wired nothing fixed it until i restarted the router.. i downloaded the firmware u said u went back to , will try that out tonight. thanks for the info
jeremyg237 wrote:
UPDATE: Went back to XR500 V2.3.2.32 and all has been working great for 3 days now. So it does have something to do with the firmware.
MeteorMike
Oct 24, 2019Guide
I'm using the newest firmware and I'm havin the same problem. XR500 Device Manager Network Map shows several devices offline that are connected. I have tried the reboot fix but that is just a pain to do over and over. I haven't tried going back to the older firmware but I may try that this weekend.
