Fuzy
Oct 16, 2018Apprentice
XR 500 OPTION 60
Hello,
In order to connect the XR500 live behind my ONT Fiber Optics, I need to have option 60 (send vendor class) in the DHCP option.
But it is not only present option 61.
I would like to know if this DHCP option will be present in a future Frimware?
1 Reply
- Netduma_JackNetDuma Partner
I believe this option is only available on NETGEAR modems (e.g. D7000 range). NETGEAR write all the code for this section, so if you would this feature added, I recommend you contact them here: https://www.netgear.com/support/contact.aspx
Others on this forum may know better though!
