PhillyEagles44
Jul 01, 2020Aspirant
Xr 500 slow internet speeds when a few devices connect
So I recently upgraded from a AC 1750 router to my new XR 500 Nighthawk. I pay for 400 mbps internet and when I run a speed test I usually get around 340-320 mbps. Now I live in a house with a couple ...
Netduma-Fraser
Jul 01, 2020NetDuma Partner
What is the XR connected to - a modem/router combo or just a modem? If the former, are there devices connected to that also? As I would recommend ALL devices are connected to the XR. Then I would recommend you re-enable QoS, make sure you've put the correct speeds in Bandwidth Settings. Then use 'Always' for Anti-Bufferbloat with 70% set for both download and upload. See how you get on then.
PhillyEagles44
Thank you for the reply, and yes it’s connected to just a modem, and there is only my house phone line connected to modem besides the XR, and two things (my pc and one smart tv) are hard wired to the XR thru cat 6 cable, and I used to have the anti buffer on but it seemed like it was much worse with it on then with it off, but I will for sure give it a shot
- Netduma-FraserJul 01, 2020NetDuma PartnerDo give it a go as that feature was designed to combat the very situation you've described.
- PhillyEagles44Jul 01, 2020Aspirant
The last time i had it turned on it seemed to make my issue worse. I will give it a try now as i am home now, also one other thing i am having a issue with is the router kicks people off the wifi and makes you re-connect 5-10 times a day (atleast what my buddy told me)
- Netduma-FraserJul 02, 2020NetDuma PartnerIs this just for wireless devices or wired devices as well? Use a WiFi analyzer to find the least congested channels in your area and change to those, see if that helps.
