brosis11
Feb 09, 2020Aspirant
xr 500 wifi help 2.4ghz connects but 5ghz wont let me
I can connect to my 2.4ghz wifi with no problem but i can't connect to my 5ghz wifi on my phone. it says "unable to join network"
- Feb 09, 2020Forget the WiFi completely on your device and then reconnect with your new password. Also ensure HT160 is disabled in Settings > Advanced > Advanced WiFi Settings on the router.
brosis11
still says "unable to join network"
Netduma-Fraser
Feb 09, 2020NetDuma Partner
