codemansanchez
Dec 04, 2019Aspirant
Xr 500
Xr500 keeps dropping Internet all lan devices just DC and wifi wi display it's up but eventually it won't be I'm thinking it's my modem possibly no specs for it because I'm not home but it's through c...
codemansanchez
Dec 05, 2019Aspirant
WiFi. Neighbors dozen including screenshot of the list of them and I do have the wifis seperate on the router between 2g and 5g and I also was told by my roommate he hadn't dced at all till I got home at around 1 am and Its always happening when I'm playing CoD could be the problem it seems like CoD
And the isp modem model # is attached and visible in picture
- FURRYe38Dec 05, 2019Guru - Experienced User
The modems model # is not seen in the picture. Those are MAC addresses which you should not make public in posts.
We are looking for the Mfr of this modem and the model#.
Are you using wired or wireless for gaming?
Manual or auto for channels? What channels are you using?
- codemansanchezDec 06, 2019Aspirant
ok the modem model number is E31n2V1 by Hitron Technologies, Inc. DOCSIS 3.1 eMTA
and im using wired and for wifi channels im using auto on 2.4 and the 2.5 was set to 161
and here is the log of events everytime
DumaOS] Error parsing line in ARP table: 'fe80::12f1:f2ff:fe47:15cc dev br0 lladdr 10:f1:f2:47:15:cc STALE', Friday, December 0
[DumaOS] Error parsing line in ARP table: 'fe80::201:5cff:fe6b:a46 dev brwan lladdr 00:01:5c:6b:0a:46 router STALE', Friday, Dec
[UPnP set event: add_nat_rule] from source 192.168.1.153, Friday, December 06, 2019 01:46:09
[admin login] from source 192.168.1.10, Friday, December 06, 2019 01:45:16
[UPnP set event: del_nat_rule] from source 192.168.1.153, Friday, December 06, 2019 01:43:23
[DoS Attack: ARP Attack] from source: 71.95.32.1, Friday, December 06, 2019 01:41:24
[DumaOS] DHCP lease change., Friday, December 06, 2019 01:29:54
[DumaOS] DHCP new event., Friday, December 06, 2019 01:29:54- codemansanchezDec 06, 2019AspirantUpdate after talking with spectrum the issue occurred around the time I posted in the logs but the only thing that happened like I said was the modem reset eventually but I spoke to tech support and they said there was no issues seen on their side of things
