WillDahBeast
Oct 29, 2022Aspirant
xr 500
Hey everyone! I've had this problem for about 2 years now and have just kinda dealt with it. Trying to login to WebGUI I get error "DumaOS not loaded yet! Don't worry we will redirect you ...
Oct 29, 2022Guru - Experienced User
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- WillDahBeastOct 30, 2022AspirantThanks for the reply.
I did as instructed but get a "connect request failed" when trying to send the firmware with CMD.
I am able to ping the device, and I have waited for a reboot and orange LED on power.- Netduma-FraserOct 30, 2022NetDuma PartnerDid you set the static IP correctly on your ethernet adapter as well as ensuring you're in the right directory where the firmware file is?
