WillDahBeast
Oct 29, 2022Aspirant
xr 500
Hey everyone! I've had this problem for about 2 years now and have just kinda dealt with it. Trying to login to WebGUI I get error "DumaOS not loaded yet! Don't worry we will redirect you ...
WillDahBeast
Oct 30, 2022Aspirant
Thanks for the reply.
I did as instructed but get a "connect request failed" when trying to send the firmware with CMD.
I am able to ping the device, and I have waited for a reboot and orange LED on power.
Netduma-Fraser
Oct 30, 2022NetDuma Partner
Did you set the static IP correctly on your ethernet adapter as well as ensuring you're in the right directory where the firmware file is?
