Rjaaayyy
Jul 12, 2024Aspirant
Xr 500
I have an installation stopped problem on my xbox, not allowing it to update or download games consistently . After all troubleshooting on the Xbox and even a new Xbox it still persist. Any idea what ...
Jul 12, 2024Guru - Experienced User
Is game consoles wired or wireless connected to the XR500 router? Ethernet is preferred.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Be sure to disable any QoS on the XR router temporarily to help check this.
