Fadii
Feb 06, 2023Guide
xr 700 gaming lag
Hi i have my xr700 router configured for gaming, its been working great for quite some time. All of sudden, is started experiencing lag while gaming although latency is ok. I play warzone 2 and some...
Fadii
Feb 06, 2023Guide
The SP router is a Huawei GPON router and is actually providing a dynamic IP address to the WAN interface of XR700.
I am did the steps your recommended and will do some testing now. I also replaced the PS5 cable with a new one.
Feb 06, 2023Guru - Experienced User
If your ISP Modem/ONT already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Try option #2 first...
