Misanthrope
Aug 14, 2020Aspirant
XR 700 Teredo Issues
I recently switch from xr500 to xr700. I have ATT fiber, so I’m stuck using their gateway, unfortunately. It’s a BWG210-700. I setup IP pass through on the gateway for the router. When I try to con...
Netduma-Fraser
Aug 14, 2020NetDuma Partner
Go to WAN Settings and change NAT to Open, does it then work correctly on the Xbox?
- MisanthropeAug 14, 2020AspirantIt does not work. I still get an unavailable NAT type.
- Netduma-FraserAug 14, 2020NetDuma PartnerIf you disable the Geo-Filter does it give you a NAT reading?
