TTedd
Oct 04, 2020Aspirant
XR1000 - Bufferbloat - False negative?
Hello all, I have been running the XR1000 for the past week. Enoutnered a few bugs/issues, but real reason here is to query others on their bufferloat (DSL reports) experience. I am seeing a degrad...
Netduma-Fraser
Oct 04, 2020NetDuma Partner
I wouldn't really give much credence to DSLReports to be honest. That is why we added Connection Benchmark, I would recommend you try different CC settings to get the Ping Under Load test results down as much as possible and then it should be as optimized as possible. We have had that suggestion before so likely we will add it in the future.
TTedd
Thanks for response. Having not had much run time on the unit it is hard to assess actual performance in the real world, hence my post. The results though being so destinctly and repeatably different raised doubts and questions. At this point I will trust the internal benchmark (which is really nice added feature) and move forward :)
