Yasd7's avatar
Yasd7
XR1000 - Geo filter interface keeps refreshing during mid gaming. Slow speeds in general
Hey, Merry Christmas to those that are celebrating, hope it's a blessed day.
I was previously using the XR500 for around 5 years, before unfortunately it randomly died on me.
Yesterday was my 1st day of having the XR1000 as a replacement.
The general speeds on all devices are slower than when I used the XR500. No idea what's happened?
The Geo Filter is refreshing everytime when I'm gaming & causing frustration & an inconvenience. When it refreshes, it just takes me back to the sign in page where my username & pword show
I've ran a speed test via benchmark & it's coming up to pretty much what my ISP is providing, getting 900mb + up & down as I'm on a 1GB plan for up & down on Community fibre in the UK.
I'm on the latest firmware as of today.
Can someone please urgently help me, as if these major issues can't be fixed, then I'll have to return it.
Thank you and hopefully look forward to a fix
  • It sounds like you may be using armor is that the case? If so disable that and then see if you get the same issue after a reboot please. Merry Christmas!
    • Yasd7's avatar
      Yasd7
      Hi.
      Hope you had a good Christmas.
      Thanks for the reply.
      No, armour hasn't even been activated as I heard it slows down speeds etc, so didn't bother activating it
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Thanks and you! What web browser/device are you using to access? It sounds like the browser or interface is timing you out
