hajnerkrisztian
Feb 02, 2024Aspirant
XR1000 - high ping on 2.4Ghz
Good morning, I would like to ask for your help. I have an XR1000 router and I am having trouble recently with the2.4Ghz wifi network. I am trying to run a connection benchmark within DumaOS,...
Netduma-Fraser
Feb 02, 2024NetDuma Partner
What is the model of the modem/router the XR is connected to and how have you set that to ensure all traffic flows to the XR? E.g. XR in its DMZ, modem/bridge mode
Have you disabled Smart Connect?
hajnerkrisztian
The modem is a CM1000.I dont know if it is set properly or not, to be honest. Smart connect is disabled, yes.
- Netduma-FraserFeb 02, 2024NetDuma PartnerWhen you're doing the speedtest.net test is anything happening on the network at the time? How do you have Congestion Control setup?
