Cubiksrube54
Aug 02, 2021Tutor
XR1000 - How to get public IP in double natted scenario
Sorry, my model wasnt listed in the Model dropdown. Its in the title. As the title states - I'm in a double natted scenario, where my old Router was able to log into my PPPoE internet and get a sec...
antinode
Aug 02, 2021Guru
> XR1000 [...]
Firmware version? Connected to what?
> [...] I'm in a double natted scenario, [...]
I have no idea what that means to you. How, exactly, did you arrive
at that conclusion?
> [...] my old Router [...]
Somehow, I seem to have forgotten everything about it. Please
refresh my memory.
> [...] get a second public IP [address?] no problem at all.
Two "public IP" addresses? What are they? Where are they?
None of that is a useful problem description. It does not say what
you want. It does not say what you did. It does not say what happened
when you did it. As usual, showing actual actions (commands) with their
actual results (error messages, LED indicators, ...) can be more helpful
than vague descriptions or interpretations.
> How can I achieve that with this router?
I don't know what "that" is. I know nothing about your (unspecified)
"my old Router", or how you configured it. I know nothing about how you
configured the XR1000, or what about it doesn't satisfy you.
