SentinelForce
Sep 24, 2023Aspirant
XR1000 - No longer password protected
Woke up this morning to find that our router to the house is no longer secure. Both connection points are now unprotected and I can't access the routerlogin "404 not found" What should I do? I've ...
Netduma-Fraser
Sep 25, 2023NetDuma Partner
If you can't access then you will need to factory reset first, hold the reset button for 30 seconds, then wait 4 minutes before accessing the interface and see if you can go through the Setup Wizard. If you can there will be a point there where it will check for and download/install the latest firmware.
