Xcel
Feb 15, 2021Apprentice
XR1000 - Not getting full speeds during speed tests (speedtest.net)
Without the router in the loop, I consistantly get 940Mbps down and 920Mbps up. With it between my computer and the ONT I get 760ish down and 780-820 up. This is with Congestion Control at 100%.
Xcel
If I completely disable QOS, I get near full speeds. When running the tests with QOS on, I have other devices connected to the router but they are not actively accessing the internet.
- Netduma-FraserFeb 15, 2021NetDuma PartnerWithout QoS disabled what settings have you changed on QoS? Are you using Armor, Traffic Controller etc?
- XcelFeb 15, 2021Apprentice
Armor is disabled, not using traffic controller, added Xbox to traffic prioritizaion and disabled all devices, Bandwith allocation left at default
- Netduma-FraserFeb 15, 2021NetDuma PartnerHow did you add the Xbox to Traffic Prio specifically - did you use manual ports?
