Xcel
Feb 15, 2021Apprentice
XR1000 - Not getting full speeds during speed tests (speedtest.net)
Without the router in the loop, I consistantly get 940Mbps down and 920Mbps up. With it between my computer and the ONT I get 760ish down and 780-820 up. This is with Congestion Control at 100%.
Netduma-Fraser
Feb 15, 2021NetDuma Partner
Without QoS disabled what settings have you changed on QoS? Are you using Armor, Traffic Controller etc?
Xcel
Armor is disabled, not using traffic controller, added Xbox to traffic prioritizaion and disabled all devices, Bandwith allocation left at default
- Netduma-FraserFeb 15, 2021NetDuma PartnerHow did you add the Xbox to Traffic Prio specifically - did you use manual ports?
- XcelFeb 15, 2021Apprentice
I added it as a games console. No settings changed
- Netduma-LiamFeb 16, 2021NetDuma Partner
How are you measuring your speeds, using a third party application like speedtest.net, or Connection Benchmark?
I'd suggest doing both and comparing the two results.
