Xcel
Feb 15, 2021Apprentice
XR1000 - Not getting full speeds during speed tests (speedtest.net)
Without the router in the loop, I consistantly get 940Mbps down and 920Mbps up. With it between my computer and the ONT I get 760ish down and 780-820 up. This is with Congestion Control at 100%.
Xcel
Armor is disabled, not using traffic controller, added Xbox to traffic prioritizaion and disabled all devices, Bandwith allocation left at default
Netduma-Fraser
Feb 15, 2021NetDuma Partner
How did you add the Xbox to Traffic Prio specifically - did you use manual ports?
- XcelFeb 16, 2021Apprentice
I added it as a games console. No settings changed
- Netduma-LiamFeb 16, 2021NetDuma Partner
How are you measuring your speeds, using a third party application like speedtest.net, or Connection Benchmark?
I'd suggest doing both and comparing the two results.
- XcelMar 10, 2021Apprentice
Sppedtest.net (many servers)
