Xcel
Feb 15, 2021Apprentice
XR1000 - Not getting full speeds during speed tests (speedtest.net)
Without the router in the loop, I consistantly get 940Mbps down and 920Mbps up. With it between my computer and the ONT I get 760ish down and 780-820 up. This is with Congestion Control at 100%.
Netduma-Liam
Feb 16, 2021NetDuma Partner
How are you measuring your speeds, using a third party application like speedtest.net, or Connection Benchmark?
I'd suggest doing both and comparing the two results.
Xcel
Mar 10, 2021Apprentice
Sppedtest.net (many servers)
- XcelMar 10, 2021Apprentice
They are slower on both speetest and the internal router test.
- Netduma-FraserMar 10, 2021NetDuma PartnerReset bandwidth allocation even if you haven't changed it and test again please
That seemed to get me pretty close. How often will I need to do do this? I have never set anything manually on the distribution
- Netduma-FraserMar 10, 2021NetDuma PartnerJust doing it that one time should be enough, keep us posted!
